Hi does anyone have a file or a code to remove macrovision from phillips dvd player dvp642.
There is none,Only to DVD recorders,But no to VHS,uless you have upgraded the firmware.
This issue has been discussed at great length. Go here:
https://www.videohelp.com/dvdhacks.php?select=Philips+DVP+642Still a few bugs in the system... -
Hi i tried to use the firmware and it did nothing.I still cant even record to a vcr .The macrovision is still there.
OK, what is your current firmware and do you have a model with the E designation. If you have 1109 and an E designation you can't go back to 531 and you will be unable to remove Macro.
Easycap Video Capture Adapter VHS to DVD Macrovision Removal.
By Teac23 in forum Capturing and VCRReplies: 11Last Post: 23rd Aug 2012, 12:19 -
What to buy today for Macrovision removal (VHS tapes).
By cowmix in forum Capturing and VCRReplies: 3Last Post: 10th Mar 2010, 17:18 -
Phillips DVP642/37 help with DTS Audio problems
By cram_it_2000 in forum DVD & Blu-ray PlayersReplies: 6Last Post: 24th Sep 2008, 15:29 -
phillips dvp642
By bored23 in forum DVD & Blu-ray PlayersReplies: 8Last Post: 11th Mar 2008, 07:54 -
Makeing NeroDigital Run on a Phillips DVP642
By Trident5 in forum DVD & Blu-ray PlayersReplies: 18Last Post: 2nd Mar 2008, 00:13
