Hi,
Does anyone know of a software that's able
to join large mpeg files?
Tried that but it just eats all the memory, it tries to read all the files that i want to join into memory, about 1.4 Gb.
Also try vcdcutter. It might not let the audio and video go out of sync if tmpgenc does.
I have no trouble using TMPGEnc to join multiple MPEG files. I've done in excess of 700MB and I've only got 256 MB RAM. Regardless I think TMPGEnc is smart enough to use your Swap or Paging file if needed.
If you want to try something else try Wincode an old 3.1 Windows application that joint/splits, does UUE encoding/decoding, etc..
Free software to split large MPEG-PS file into many small MPEG-PS files?
By videonewbie22 in forum Newbie / General discussionsReplies: 9Last Post: 5th Jul 2018, 20:16 -
So what's the best software for joining mpeg-2 files together?
By snafubaby in forum EditingReplies: 1Last Post: 23rd Aug 2009, 04:15 -
GUI for dvdauthor, movie from 2 MPEG files instead of joining them together
By Steve Walsh in forum Authoring (DVD)Replies: 5Last Post: 4th Sep 2008, 10:13 -
Joining mpeg-4 files
By GAR in forum EditingReplies: 8Last Post: 3rd May 2008, 23:42 -
Joining 2 mpeg files together
By efiste2 in forum EditingReplies: 3Last Post: 28th Jul 2007, 08:37
