  1. how am i suppose to add templates that i have saved ?!?!?! when i add it to the templates folder nothing happens when i close and reopen tmpgenc program !!!!
  2. Click "Load" (right bottom) select the template.
  3. Are you putting in a NAME for the template?
    Cheers, Jim
    My DVDLab Guides
  4. yeah i'm saving it under a different name and i put it in the template folder ... when i close tmpgenc and open it back up(the wizard) ain't there ?!?!?!
    i even loaded an old template (video cd(pal)) since i don't use that template and changed the settings (actually i just made a duplicate of the ntsc and changed some settings and then renamed it to the video cd(pal) template) and it still wouldn't recognize the settings ... wondering what's going on !
  5. okay i figured it out. i opened the template file and deleted the $$hide between the ' ' ... and that did it.
