    Feb 2005
    Hungary
    hi
    iam using avisynth 2.55 (so lanczos4resize supported)
    iam following this guide:
    https://www.videohelp.com/forum/viewtopic.php?t=221896
    Well when iam trying to write my own .avs
    it has a problem with X values at cropping.
    letme see vdub says x1: 5 y1: 34 x2: 6 y2: 34
    MPEG2SOURCE("fc.d2v")
    Crop(5,34,-6,-34 )
    error is:
    Crop: YUV images can only be cropped by even numbers (left side).
    i tried with other numbers, only x1 value other was 0 etc.
    the fact is, if i used x values i got an error only (0, Y1, 0, -Y2) works
    thanks blas.
    Dec 2004
    Australia
    If you want to crop a single pixel then you need to convert to RGB first (not recommended).
  3. Crop(6,34,-6,-34 ) should worrk
