Is there an easy way to backup captured video (40Gb) ?
Can I convert the DV AVI to a smaller format without quality loss, in order to write everything to a couple of DVD's (as backup) ?
What do I need for this and how do I do it ?
Thanks a lot for the help ...
Yoeri
If you compress to a smaller size you WILL lose quality. By compressing you are throwing away some of the data and, once gone, you'll never get it back. The only way of keeping the quality would be to leave it as DV .avi. Your best bet for backing up would be to output it through Firewire back to your camcorder and save it on DV tape.
Here's what I do with my DV home movies. Because watching a DVD is so much easier than watching the video from the tape (Set chapters, FAST forward, no waires to connect if you have a DVD player, etc) I am willing to have a small quality loss (barely noticable or not at all) in the conversion.
The added benefit to this is that with a little more work, you can edit out all the boring crap that you never want to watch again and set up "chapter" points named for the clip they represent so watching what you want is easy.
However, rather than discuss how this is done when you may already know, I'll just stop there and see if i was even close to what you were asking about. Maybe your end use is totally different.
Dazzle dvc100 w studio 12 does it capture AVI 1 or AVI 2 or DV-AVI
By st711 in forum Capturing and VCRReplies: 1Last Post: 10th Dec 2009, 17:30 -
avs (avi to avi) ends up out of sync ... winavi output file too big
By mandy in forum Video ConversionReplies: 1Last Post: 21st Aug 2009, 05:56 -
ffmpeg choppy audio from large avi but not small avi source file
By cybertheque in forum Capturing and VCRReplies: 9Last Post: 13th Oct 2008, 15:38 -
ffmegX v0.09w and converting avi videos into avi.ff.avi videos
By paddymick in forum ffmpegX general discussionReplies: 2Last Post: 2nd Nov 2007, 23:10 -
How To Split Single DV AVI file into Multiple DV AVI files using Time Stamp
By insysnet in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 23rd Aug 2007, 12:49
