  1. SSIA. How can I add a caption or hallmark that pops up for only a few seconds to my video? I work with DV-AVI files.
    Apr 2004
    Miskatonic U
    You need an editor or similar that allows overlays with alpha channels and varying opacity. There might even be a filter for virtualdub to do this.
    What software do you have available ?
    Read my blog here.
  3. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Yes, the logo filter for VirtualDub does the trick. I think Jimmalenko has even written a guide for it!?!?
    /Mats
  4. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    https://www.videohelp.com/guides.php?guideid=714&howtoselect=5;23#714 might help.
    If in doubt, Google it.
