Ive got files that wont burn cause theyre ogg files. Anyone know how to change them to mp3 or a burnable format?
"Be excellent to each other." - Ted Theodore Logan
I take it you're burning standard CD Audio discs? If that's the case, I'd output to uncompressed .WAV files so you don't add more lossy compression before burning such as MP3 compression. I've used dbpowerAMP for years, it's free and it does a great job, and it supports just about any audio format you can think of. I'd suggest that, it can batch encode as well so you can do them all at once.
Could also use Foobar2k, Nero, burnatonce, BlindWrite, etc. to convert and burn them in one go.
I second dbpowerAmp. I've been using it for the last couple of years, after trying many others, & find it the easiest & best audio converter. You can change most any format to any other format with just a couple of clicks. Even RA to mp3. Try it, you'll like it.
Hybrid(Windows/Linux/Mac): Input -> x264/x265/Xvid/VP8/VP9
By Selur in forum Video ConversionReplies: 2378Last Post: 27th Nov 2025, 10:38 -
how do you convert .ogg audio file to mp3?
By shun in forum AudioReplies: 5Last Post: 22nd Sep 2023, 16:34 -
Trouble converting VBR Ogg to MP3
By Ryutso in forum AudioReplies: 2Last Post: 3rd May 2009, 15:19 -
Help: How to convert .rad to other format (mp3/wav/ogg/etc)?
By Nator in forum AudioReplies: 1Last Post: 11th Sep 2008, 21:06 -
How do I convert .MP3 to .OGG directly?
By Cobra in forum AudioReplies: 11Last Post: 9th Oct 2007, 15:04
