I have made my first SVCD (using TMPENgc converted a DivX movie, and burned using InstantCD+DVD) The movie only takes up about 1/4 of the Top Left corner of the screen when i put it in my DVD player.
I have tried encoding it diffrently with other setting in TMPENgc and even followed the VCD Help's Guide to make a SVCD.
Does anyone know what Is wrong or how to correct it?
<font size=-1>[ This Message was edited by: syzygy on 2001-12-10 01:00:15 ]</font>
did you preview the file in TMPGENC before encoding to make the aspect and centering looked ok?
Yes, When I play it on my PC it looks fine. It seems that as soon as I put it on CD it doesn't work.
had similar problem xvcd's. because i wasn't using standard resolutions from the templates. if you load the template before you load the file, the resolution of the source file is what stays. check to make sure it is encoding at 480x480 for svcd.
VirtualDub filter to insert video from another source into a corner?
By Riothamus in forum EditingReplies: 2Last Post: 6th Jun 2011, 07:51 -
Zoom / Small blue box bottom right corner of screen on Philips DVP-3252
By DVP-32 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 25th Jul 2008, 14:34 -
.AVI File Displays Time on Screen - How to Remove?
By Blacklight in forum Software PlayingReplies: 6Last Post: 15th Jul 2008, 10:30 -
Vobsub causing pixelation on upper RH corner?
By Uzysuicide in forum SubtitleReplies: 2Last Post: 7th Feb 2008, 17:13 -
My DivX movies randomly blocking up only in the upper-right corner... (pic)
By sofakng in forum Newbie / General discussionsReplies: 6Last Post: 9th May 2007, 15:21
