I tried the method described by BALDRICK and that got what I wanted except for one big probelm - the (fake) .avi that it outputs plays low video quality. The .vob's play nicely in a player, but after I go through the process described by him the video plays lower quality (especially visible duing quick movements). I don't know why this is as his process never encodes the video. Any explanation and/or what to do?
Results 31 to 34 of 34
Baldrick, I did do that and tried to export as uncompressed .avi and the file it made was low quality just like it was before I pulled it into premiere.
The only way I've been able to accomplish what I want to do is by by-passsing Premiere altogether. Here's what I did:
1) Ripped DVD contents to hard drive using Rejig
2) Used Mpeg Video Wizard to edit contents
3) Used TMPGenc DVD Author to make the new DVD
Is that a good process? I'm just bummed that now I have to buy a new video editting program and not be able to use Premiere for this kind of project. -
Besides the Frameserving method by Baldrick (wich I'm sure would work, but I haven't tried it yet), You've got a few other choices.
The quick and dirty way would be to load the Vob in Vrtualdub mod and save as dv-avi using the free Panasonic dv codec. You will have no problems editing it in Premiere.
The better solution (if you have HDD space), is to load vob into Virtualdub mod and save to Huffyuv avi. The quality will be the best you can get. Premiere can edit the Huffyuv, though it will be a little slower.
Can't edit video file converted from DVD to AVI in Adobe Premier
By GalMed in forum EditingReplies: 12Last Post: 24th Feb 2012, 14:53 -
ripped dvd's to avi, which route?
By ojfish247 in forum Newbie / General discussionsReplies: 1Last Post: 21st Feb 2008, 20:21 -
AVI to DVD conversion ( don't need Menu )
By rock in forum Newbie / General discussionsReplies: 1Last Post: 16th Sep 2007, 03:54 -
Still don't understand .avi to DVD input/output
By sknox in forum ffmpegX general discussionReplies: 1Last Post: 2nd Jul 2007, 14:51 -
Ripped/burned AVI DivX files not playing in pc or DVD player
By perceptionist in forum DVD RippingReplies: 13Last Post: 4th Jun 2007, 04:55
