Hey, I'm trying to encode a SVCD it's 72 minutes 12 secs, i wanted to fit it onto one 80 Min disk, but after encoding it, it was 785 megs and the bitrate i used was 1275, (used the bitrate calculator from the Converting to SVCD section of vcdhelp.com) i have tried this twice already and that is about 48 hours of wasted time cause each time i can't get it to get down to 700 or below, so can any1 tell me what bitrate i should use to get it down but not lose so much quality or is this just crazy?
The 785 MB result is perfect! An SVCD is written in Mode2 (without error correction bits), so in reality an 80 min. disc can hold about 800 MB of data.
yes, this is a good number for an 80 min disk.
Using CDRWIN to bern CDz with the BIN/CUE option (which
'sees' CD-images as Mode 2, will rip a plum-full CD to this
size.
I never understood at the time.
There are three standard block sizes on CDR/CDROM/CDRW discs:
sizes are bytes per block.
2352 - raw mode.
2048 - Mode1
2336 - Mode2
the 785 size you are seeing is probably Mode2 compatible. 2048 blocks will give you the ~700meg file size.
Should i put average bitrate or max bitrate in 2pass encoding mode?
By tendra in forum Video ConversionReplies: 28Last Post: 11th Nov 2011, 07:38 -
Question about bitrate, spikes and Bitrate viewer
By sasuweh in forum Authoring (DVD)Replies: 3Last Post: 25th Oct 2010, 15:01 -
Using mutiple passes with lower bitrate vs single pass with high bitrate on
By jones24 in forum Newbie / General discussionsReplies: 15Last Post: 14th Aug 2009, 18:17 -
Most compatible codec, Lossless bitrate, and max bitrate
By sevenlayercookie in forum Video ConversionReplies: 2Last Post: 6th May 2009, 20:43 -
Low bitrate source to High bitrate target
By sameerdhiman in forum Newbie / General discussionsReplies: 2Last Post: 7th Nov 2008, 23:54
