I have Vegas Movie Studio, VirtualDub, etc.
Currently, I'm capturing older Hi8 stuff using Canopus' ADVC100 capture box.
Vegas Movie Studio allows me, per clip, to slow down or speed up a clip. The problem is, the speed up is only 4x.
What steps do I need to do to the AVI to get it to playback really fast (for effects, time lapse, etc.)?
How would I get a clip to play in reverse?
Speed it up 4x, save, reload, speed it up 4x again, save, reload...
Cheers, Jim
My DVDLab Guides -
reboot... there has to be some filter out there that can work with Vegas for time envelopes?
I don't want to lose quality by compressing the stream over and over again. ??
Is there nothing out there that can look at every 'n' frame, extrapolate motion and such to the next 'nth' frame; write out a new stream that would be played back at 29.x FPS for the project?
I looked at Twixtor, but I don't think it works with Vegas... -
Well in my example it selects every 100'th frame and then changes the framerate back to 29.x FPS.
Thanks, Celtic. I'm just completely AVISynth ignorant. I'll try to work with it. Is it working in conjunction with VirtualDub?
Any software to rename file based on video properties? good question!
By thomseye in forum Newbie / General discussionsReplies: 10Last Post: 18th Oct 2012, 17:07 -
Sync/align one short clip into one big clip
By diamondback in forum AudioReplies: 1Last Post: 2nd Nov 2011, 09:31 -
Final Cut - Matching Clip Properties To Sequence?
By toxicquack in forum MacReplies: 2Last Post: 26th Jan 2009, 16:13 -
Do I need to stop clip analysis in order to export clip for dvd
By maevek1 in forum MacReplies: 0Last Post: 9th Apr 2008, 08:26 -
How to convert wmv clip so its properties match other wmv clips
By sohaibrazzaq in forum Video ConversionReplies: 4Last Post: 4th Aug 2007, 09:16
