Results 1 to 11 of 11
  1. Hey whats a top class dvd decrypter to use. The one u get from http://www.dvddecrypter.com/index.php?act=download i find that it does not work with the later dvds.
  2. Dvd decrypter works fine. Which version are you using?
    Life is like a pothole, you just have to learn to get around it.
  3. Member Sifaga's Avatar
    Aug 2003
    Melbourne, Australia
  4. hey im using the 3.5.2.0 version. I tried to copy my mates dvd layer cake i have used dvd decrypter several times but it is only just now that it just does not copy the dvd and i get write errors which i never got before. Cheers for the replys
  5. The latest AnyDVD is supposed to beat the new protection. Hmm, let's see, have you tried DVDDecrypter in File Mode, then reauthor main movie with DVDShrink? And you could look into settings in DVDDecrypter under CSS and Detect Mastering Errors, what is the setting? Been some threads on this lately, you might try a search. Good luck.
    Pull! Bang! Darn!
  6. Member Sifaga's Avatar
    Aug 2003
    whats a dvd layer cake ?
    are you having the problem ripping to your harddrive or burning an ISO ?
    what are the errors ?
  7. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    It's a layered cake made with dvd's :P
    I think he is talking about "layer cake" some movie......
    https://www.videohelp.com/forum/viewtopic.php?t=261289&highlight=cake
    VobBlanker has also ripped disc's that would get hung on DVD Decrypter, older ones without the new weird protection. I have a set of 12 import dvd's in a series, all ripped perfect with DVD Decrypter except one, thought it was scuffed or something, tried cleaning it, no go, pulled out VobBlanker
    Although DVD Decrypter is still my #1 ripper!!
  8. Member Sifaga's Avatar
    Aug 2003
  9. EDIT
    (see sig below)
    If God had intended us not to masturbate he would've made our arms shorter.
    George Carlin
  10. Member Sifaga's Avatar
    Aug 2003
    hey shocker,
    whats the lovely ladys name ( Avatar)
  11. Hell, I don't know.
    George Carlin
