When transfering from DV to Avid, does this actually transfer to a DV file or do you have to select a DV codec and export to the DV format?
I just couldn't find a way to export my capture and didn't want to re-encode to DV twice.
Thanks for any help.
It's been awhile since I used it but Avid Free DV seemed to do what the others do, that is ...
transfer the DV stream to a temporary DV-AVI file, then extract from this file or group of files to create a timeline project file. The project file contains only edit list data. A new DV file is created only when you export.
Media Express 3.0.3 Question?
By Darkensteele in forum Capturing and VCRReplies: 0Last Post: 27th Dec 2011, 05:47 -
Blackmagic Media Express question
By trialanderror in forum Capturing and VCRReplies: 0Last Post: 5th Mar 2010, 01:21 -
Looking for Avid Free DV for Mac
By lordsmurf in forum MacReplies: 0Last Post: 2nd Mar 2010, 04:55 -
Final cut express simple question
By thecrock in forum MacReplies: 1Last Post: 17th Apr 2009, 11:48 -
final cut express HD... quick question
By ednarophati in forum MacReplies: 1Last Post: 10th Jul 2007, 11:32
