I have some mpeg2 files recorded on a wintv nova t in pal that I wish to view with XBMC on my xbox.
If I watch the files in their original recorded size (704x576 16:9) there is no interlace, but much of the picture is missing as the TV is 4:3. If I customise the display in XBMC the interlace appears.
I have tried to re encode to remove the interlace, which works fine for small files but larger ones have audio sync problems. Not sure about all the correct settings.
What I want to do is just purely remove the interlace and change nothing else. How can this be done? These are just recording from the TV made digitally instead of using a VCR. I want to try and avoid spending ages with audio sync issues etc and using various programs to reach the end result if possible. Have tried encoding to mpg, xvid divx with canopus procoder 2 and played with virtualdub but had more audio issues with this, not sure if I should play with the audio stream before encoding?
Results 1 to 1 of 1
interlace help
By nymph4444 in forum Newbie / General discussionsReplies: 339Last Post: 17th Jun 2011, 02:33 -
Interlace or Bitrate ??
By garylanders in forum Authoring (DVD)Replies: 14Last Post: 4th Jan 2011, 05:14 -
How to remove the remove redundant tracks of *.ts?
By UMO in forum Newbie / General discussionsReplies: 6Last Post: 27th Feb 2010, 00:30 -
Question about HD to SD and interlace>progressive>interlace
By ayim in forum Video ConversionReplies: 4Last Post: 10th Dec 2009, 12:21 -
Interlace or Progressive??
By Browncoat in forum Newbie / General discussionsReplies: 9Last Post: 31st Jan 2008, 15:14
