Here's my problem.
I'm trying to convert a .avi with 23.97 fps using TMPG. I convert it using these settings..
[/img]
I then play it in Power DVD, it's smooth and in sync, then I author it and burn it with Movie factory 2 (which for some reason wants to render it and it takes an age)....
The resulting DVD is smooth but out of sync'.
I tried removing the audio from the .avi and remuxing it withthe video before authoring but that didn't work either.
I tried frameserving to CCE with FitCD but the aspect reatio was'nt right and the sync' was worse than ever.
Any thoughts or alternative methods appreciated.
Ta
Great, I knew that image wouldnt work.
TMPG, other settings.
Stream type, Mpeg 2 video
size, 480 x 352
Aspect 1:1 VGA
Frame rate, 23.976 fps (int 29.97)
Bitrate CBR @ 6000
Profile and level, MP & ML
Vid format, NTSC
Encode mode, 3:2 pulldown when playback
YUV, 4:2:0
DC, 9 bits
Motion search precision, HQ slow. -
Besides that odd frame size (See what is, DVD for valid resolutions) I see nothing wrong.
/Mats -
Not wonder that Movie factory want to rerender 480x352 is not supported on DVD. Should be the opposite 352x480
Thx for that guys, I've changed my template and adjusted the frame size.
Still struggling with the audio sync' tho'.
Newbie question about frame rates.
By MrTorso in forum Video ConversionReplies: 4Last Post: 13th Jul 2011, 22:49 -
Editing and rendering with multiple frame rates?
By vid83 in forum EditingReplies: 12Last Post: 2nd Mar 2011, 03:20 -
Question about Blu-ray frame rates
By Mentasm in forum Authoring (Blu-ray)Replies: 2Last Post: 26th Sep 2008, 11:16 -
Virtuadub shows two different frame rates ?
By vodmare in forum Video ConversionReplies: 8Last Post: 12th May 2008, 18:47 -
Encoding in Virtualdub: Do you have to worry about frame rates?
By FallenAngelII in forum Newbie / General discussionsReplies: 28Last Post: 7th May 2007, 11:15
