Hi there!
I have been using Nero and Nerovision Express for Months now. However, recently, when I create a dvd in nerovision express, once the burning starts, it says it writes the lead in, but then it spits out the dvd disk! Before the green bar even shows progress! I then tried to write it to hard disk and burn it on the disk using nero express, but i got to like 1% before it said the burn process failed. I went to the toolkit, and it said something about my system asci being corrupted, so i chose the nero one, but same problem! Please help! Thank you very much!
Results 1 to 11 of 11
Try a different program and see if you can burn. If so reinstall Nero (get the clean tool from Nero).
If no: if you have software issue (check your ASPI), if hardware... you know, brand new DVDRW... -
Can you burn anything at all, files, CDs, anything? I had a drive just up and die whereit works for one disk and the nest attempt to burn a movie, it wouldn't even recognize the disk let alone burn it. Has anything changed in your PC since the last time you were succssesfull. You need to tell every sordid detail around here.
No DVD can withstand the power of DVDShrink along with AnyDVD! -
Another thing you can try is to have Nero create the files on your hard drive, then burn those to your hard drive. If you still get the error messages, then you know for sure that the problem is not your hard drive. Before I did this I was getting messages that there was not enough room on the disk, when I knew absolutely that there was. By writing to the hard drive first, then burning, this solved the problem.
TANSTAAFL -
yeaaa i tried burning it to the hard drive first, but then when i went to burn it separately, it spit out the disk n gave me an error message.
i then tried to just burn some data on a cdr, n it worked perfectly!
i thought mebe id try creating the dvd on my hard drive with nerovision, n then burning it with a program different than nero? anyone have any recommendations on a good burning software? thanx! -
i definately have it set on dvd, otherwise i wudnt b able to add the video_ts files
does anyone know a good program that i can try to burn the video_ts files with? thanx!
You could create an .ISO image file from the VIDEO_TS files with IMGTools or DVD Shrink, then burn the ISO Image with DVD Decrypter.
Since you did a successfull burn to CD, more than likely your burner's dvd laser is shot/ Happened to me.
Originally Posted by cramberri
Nero will burn 4X, DVD Shrink-Nero only 2.5X
By happydog500 in forum DVD RippingReplies: 16Last Post: 4th Jan 2010, 19:49 -
XviD Encode, Playback is Jittery ~ Plz Help!
By Mark-2009 in forum Newbie / General discussionsReplies: 10Last Post: 24th Feb 2009, 11:06 -
How to burn DVD data with Nero 7?
By Kakui in forum Newbie / General discussionsReplies: 5Last Post: 28th Oct 2007, 16:00 -
Audio Cd Burning (Nero 7 Ultra Edition) NIGGLE... plz help!
By mceyedol in forum AudioReplies: 2Last Post: 30th May 2007, 14:30 -
ConvertXtoDVD to encode and burn video files to DVD
By crowheart in forum Video ConversionReplies: 15Last Post: 16th May 2007, 22:50
