Hi all, I have been reading but still confused. I have some files for example MPEG file size 759 MB and 908 and even some xvid files at 903 mb. How can I burn theses files to a CD....
thanks raz
Hi razzcal,
You can either make a VCD or an SVCD. The latter is higher quality than the former but, because you can only fit so much on to a CD, the running time of the footage will be less.
See "What Is...", top left of the page, for details on (S)VCDs. In there, it'll detail what the specs are for valid (S)VCD files: MPEG1 for VCD and MPEG2 for SVCD.
You can use GSpot to get info on your MPEG files to see if they're compliant.
For other formats, like Xvid, Divx etc. you'll need to encode them to MPEG1 or 2 as required.
TMPGEnc (the free version) will encode to MPEG1. But you'll have to pay to unlock the encoding to MPEG2 (though it's free for the first 30 days on trial). There are other encoders, look in the "Tools" section.
Once you've got your MPEGs, you can use something like VCDEasy to author and burn to CD.
Armed with the above, you should now be able to look up specific guides to answer your detailed questions.
Godo luck.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Thanks daamon, The info was very informatve I will check further for answers.......
Thanks Again Raz
Confused! Confused! Confused! VCR to DVD; major question Toshiba Diomage SV
By CAnn12 in forum Capturing and VCRReplies: 0Last Post: 5th Feb 2011, 11:26 -
Confused with Encoding
By skorpinok in forum Video ConversionReplies: 3Last Post: 29th Aug 2010, 10:40 -
Confused about XP cd reformat
By neworldman in forum ComputerReplies: 5Last Post: 22nd Jun 2010, 08:36 -
Soo confused
By slaak in forum Newbie / General discussionsReplies: 9Last Post: 10th Aug 2009, 19:44 -
Error Reading by GOM and Media Player Classic in reading MKV video
By cutefix in forum Software PlayingReplies: 1Last Post: 31st Mar 2009, 00:25
