I just installed this card and it is recording from my analong camcorder in .avi with no problems (at least not as I can tell yet - I'm pretty new to all of this), but it is not recording/capturing audio.
My machine is AMd 2200+ with 256MB DDR.
I have tried recording with the bundled Ulead VideoStudio 8 and I have sound and everything during the preview while it is recording, but on playback I get nothing.![]()
Also on playback, the video is pretty jerky.
Is anyone familiar with this problem that can offer some solutions to resolve this issue?
Thanks,
Vance
Did you set the audio source as Line In?
Cheers, Jim
My DVDLab Guides -
Have you plugged the aux out from your capture card to to your sound cards aux in?If you have then you set the record in as aux.
Well, seems that if I set it to "Stereo Mix", I get sound captured with the video.
I just opened the setup option and started at the top of the list with the intentions of trying each audio setting. The "Stereo Mix was the first on the list and it worked. However, had I not received two different suggestions for settings, I don't think I would have tried this route.
Thanks for your help,
Vance -
The setting you use, depends on how you have the audio patch cord plugged in.
Cheers, Jim
My DVDLab Guides -
You have to use that setting for the audigy (2) sound card.
Leadtek Winfast TV2000XP Expert problem with sound
By roc383 in forum Capturing and VCRReplies: 22Last Post: 1st Dec 2010, 11:32 -
Trying to use VirtualVcr with Leadtek Tv2000 expert.
By GLE3 in forum Capturing and VCRReplies: 0Last Post: 20th May 2009, 09:46 -
Leadtek Winfast pvr2000 (retail)
By fulgur in forum Capturing and VCRReplies: 7Last Post: 4th Nov 2007, 09:05 -
What is better than a leadtek expert tv tuner card?
By Gplracer in forum Capturing and VCRReplies: 1Last Post: 7th Jul 2007, 13:44 -
Leadtek Winfast TV2000 xp deluxe help
By Nuwanda in forum Capturing and VCRReplies: 0Last Post: 6th Jun 2007, 13:22
