I seem to be having difficulty in finding out what TYPE of media that can be used in the DL mode with this burner. Could someone help me ?
I think so far the only DL media available is from VERBATIM which sells the 3 packs for about $32.00. Is your drive a rebadged BENQ 1620? If you look at the box it came in, if it says DUAL LAYER DVD+R MEDIA 4x speed then it is a BTC drive. If it says 2x DUAL LAYER DVD+R then it's a rebadged BENQ 1620. Go to device manager and click on DVDROM/CDROM it should name the dvd burner.
If it is benq then try looking on aamzon for verbtim Dl media. I just bought (2) 3pks of them for $12 forthe six after rebates....
What We Do In Life, Echoes In Eternity....
Black Magic Media Express Problems
By Decerto_LethaL in forum Capturing and VCRReplies: 0Last Post: 13th Dec 2011, 10:39 -
Most compatible burner with TY mediia....
By SE14man in forum Newbie / General discussionsReplies: 7Last Post: 27th Oct 2009, 06:37 -
Can a 4x burner write to a 16x disc?
By bobarnett in forum DVD & Blu-ray RecordersReplies: 10Last Post: 24th Sep 2008, 16:47 -
lacie 16x dvd burner keeps finding miscompares while verifing dish
By loveberg50 in forum DVD & Blu-ray RecordersReplies: 8Last Post: 29th Apr 2008, 19:30 -
I/O Magic DVD ReWritable 16X Drive Not running at 16X
By mmitsch in forum DVD & Blu-ray WritersReplies: 3Last Post: 7th Jul 2007, 00:40
