I I compiled a DVD with 39 short movie clips totaling 4.09GB and made a menu with a button for each plus a Play All (made last). Using WinDVD6 I found that it woiuld not recognize anything past the 36th button as a link although I could play the last four clips manually. By authoring another compilation with the first 35 assets (3.36GB) and adding a Play All button, everything played just fine.
Was this intentional?
Also, will the final release accept .bin as assets as version 1.15 did?
I will look in to this.
bins are accepted as assets.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Menu button won't highlight
By mattblack in forum Authoring (DVD)Replies: 3Last Post: 21st Oct 2010, 17:45 -
menu button didn't work
By pcb in forum Authoring (DVD)Replies: 6Last Post: 13th Oct 2010, 15:07 -
DvdAuthorGui menu Button
By sambat in forum Authoring (DVD)Replies: 7Last Post: 15th Mar 2010, 07:04 -
Edit dvd menu button
By canaQ in forum Authoring (DVD)Replies: 8Last Post: 24th Feb 2010, 07:13 -
question about dvd menu button
By HDMI in forum Authoring (DVD)Replies: 5Last Post: 23rd Jun 2007, 22:06
