Guys,
I would like to know if there's a tool out there I can use to remove closed caption from VOB files?
Thank You
Why? Just ignore it/turn it off. Doesn't use up more than a few kB.
Scott -
I assume you mean you want to remove fixed captions, meaning those captions included in the MPEG2 encoding rather than those selectable by the player. If so then, you need to use VirtualdubMod and the Delogo filter. This will introduce a blrurring effect where the captions used to be, which will probably be more distracting than the captions....
i can't turn it off. I downloaded the movie from the internet and it has that option by default. Every other movie I have plays without closed caption. I already checked the options within the dvd and they're gray out.
Yes mh2360, Throughout the whole movie the caption is playing. Very annoying!!!
Then they're probably not closed captioned. The "closed" in CC means that they're hidden unless you turn them on with your TV/decoder.
You may have "Forced" DVD subtitles, which can be gotten around, or maybe burned-in titling, which can't.
edit--wow that was fast! missed mh2360's post.
Hey, everybody would understand better if the term "closed captions" was reserved for that actual process, maybe try to use the generic "titles" or "subtitles" which is really what you're referring to.
Once it's burned into the picture, it'll never be completely gone without ruining the picture. That's like taking the vocals out of a mono song.
difference between subtitles and closed caption
By lovelove in forum SubtitleReplies: 11Last Post: 23rd Aug 2011, 18:28 -
hdmi does not support closed caption?
By impmon2 in forum DVD & Blu-ray PlayersReplies: 22Last Post: 29th Jun 2010, 11:49 -
Closed-caption subtitles in UK
By kasfig in forum Newbie / General discussionsReplies: 4Last Post: 19th Nov 2007, 12:50 -
Extracting Closed Caption and writing it back to mpeg as open caption
By CBiLL in forum Newbie / General discussionsReplies: 1Last Post: 30th Aug 2007, 03:50 -
disabling Closed Caption Texts
By pskim in forum SubtitleReplies: 2Last Post: 5th Aug 2007, 11:36
