  1. I would like to know how to synchronize an audio delay in an AVI file, but not only that, but preserving its quality and size when I export the file...
  2. Audio, Interleaving to set delay.
    Preserve "it's" quality...do you mean video or audio?
    Cheers, Jim
    My DVDLab Guides
  3. Originally Posted by ronnieearl
    If the delay is constant, you can use VirtualDub Mod to demux and remux the video and audio streams.
    Oops my bad. After you demux the audio stream, you use BeSweetGUI to correct the delay. Then you use VirtualdubMOD to remux the original video stream with the corrected audio stream.
