I recently bought dvd moviefactory3. I've been unable to get it to convert existing MPEG2 audio tracks to ac3. I've tried using MPEG2 system files with mp2 and non-system files with wav files to no avail, even with using its 'normalize audio'. Any ideas? And if your suggestion is to "use another tool", please do not bother to post. Thanks.
As a mini review, I think this app is less friendly than moviefactory2 (which I've been using for a while), for it forgets all your custom settings for the output type every time you exit the app. It seems that they took the approach of "let's not confuse those dumbshit consumers with too may options like we did with our version 2 product". The only reason I got it was that its price was very good at Fry's last weekend. I'm not so sure it was worth even the discounted price, oh well.
Usually long gone and forgotten
Ulead dvd movie factory 2 doesn't take (or even recognize) AC3 audio. (At least mine doesn't).
Does Ulead have an AC3 plugin you need to get?Cheers, Jim
My DVDLab Guides -
i'm not sure if this applies, but i've used version 3, demo & retail for extracting video from dvd-vr's.. when i extracted the video the demo version always gave me an error about there being ac3 audio, the retail had no problems with it.. not that it mattered, because i wasnt authoring, just extracting.. you may want to check in to the retail version.
MovieFactory 3.0 "Disc Ceator" version supports Dolby Digital audio (decode, and encode 2-channel).
If your source is DVD Compliant, it gest confusing when using the "Do not convert compliant mpeg files" checkbox.
What you should try is this:
1) do not check the "Do not convert compliant..."
2) make sure your template is using a HIGHER video bitrate than your source video, and also make sure it is using Dolby Digital audio
3) Burn to your hard drive -- it should bypass the video re-encoding, but it should re-encode your audio to Dolby Digital
OR
4) another way is to check the box that says "Treat mpeg audio as non-dvd compliant", and make sure your template is using DD audio
Note 1: this is only in the Disc Creator version -- the "Standard" version does not support DD
Note 2: Some versions of MovieFactory 2.0 support Dolby Digital (specifically, the version that ships as an addon with MSPro 7)George -
Thanks GeorgeW. I'll try your suggestions. I do own the disk creator version. I love it when you have to use a "back door" with software to get it to work in the way you desire. I tried a simular approach, but I was not sure that only the audio was being encoded (it seemed the whole shootin' match was being reencoded, so I aborted it). I bought version 3 primarily for the AC3, I hope I can take advantage of it without resorting to using its encoding engine. I use many features in TMPGEnc that just don't exist in MF3.
Usually long gone and forgotten -
This converts the existing audio on imported MPEG2s to AC3. Its processing message is a little terse and some what misleading, but it does the right thing if you are patient. Thanks again GeorgeW.Originally Posted by GeorgeWUsually long gone and forgotten
Convert stereo ac3 with bad channel to mono ac3
By chipsndukes in forum AudioReplies: 7Last Post: 5th Nov 2008, 12:23 -
MPEG4-AVC (H264) + AC3 -> Divx + AC3?
By thomas_fogh in forum Video ConversionReplies: 12Last Post: 1st Nov 2008, 21:25 -
How to convert AVI/DivX/XviD with AC3 to DVD with AC3
By Baldrick in forum User guidesReplies: 52Last Post: 21st May 2008, 20:22 -
Sync issues after converting AVI (DivX 5/AC3) to MPEG2/AC3
By Greycat in forum Video ConversionReplies: 4Last Post: 25th Mar 2008, 11:24 -
H264 + AC3 + AC3 --> VOB - What is wrong with my command line?
By olik in forum ffmpegX general discussionReplies: 5Last Post: 3rd Feb 2008, 08:06
