Hello,
I am running Mac OS 10.3.8 with Developer Tools installed.
I have been test-driving ffmpegX for a couple of weeks and love it, but I started getting a kernel panic / hold down the power button to reboot message. It was working so well. I have reformated & zeroed every drive, then reinstalled 10.3 (and nothing else) and still the problem persists. It does not seem to matter what type of encodings I do, either.
I'm mostly surprised that after erasing everything, nothing has changed. Perhaps I'm missing something in the ffmpegX instal process. I have not found anything about a kernel panic on the forum, so if this has never happened to anyone else my problem probably has nothing to do with ffmpegX.
On a hunch I saved the text of this message and tried encoding in MPEG2Works, and the same thing happened.
Any help is appreciated. Thank you.
Stephen
A kernel panic may not be linked to ffmpegX, or a specific application which has no repeted behavior of such issues over many users. It may indicate hardware problems, if you're sure that your OSX install is perfect.
Check the following FAQ for directions : http://www.thexlab.com/faqs/kernelpanics.html
Critical Error (Event ID 41 Kernel-Power) causing win7 BSOD & reboots
By Denvers Dawgs in forum ComputerReplies: 5Last Post: 28th Mar 2012, 15:19 -
Difference/Relationship among encoding, re-encoding & decoding?
By iqbal88 in forum DVD RippingReplies: 12Last Post: 19th Aug 2011, 14:46 -
M$ Kernel DLS Synthetizer
By yuhr in forum Media Center PC / MediaCentersReplies: 12Last Post: 22nd Oct 2009, 20:56 -
FairUse Wizard 2.8 & MKV Encoding with VC1 & AC3
By ozzyjunk in forum DVD RippingReplies: 0Last Post: 25th Mar 2008, 13:25 -
Unexpected Kernel Mode Trap
By LITEONDVD in forum ComputerReplies: 9Last Post: 29th Jul 2007, 17:57
