I recently installed a NEC DVD writer and since then my pre existing Hitachi DVD ROM will only play an Audio CD and refuses to recognise DVD.
I have tried swopping the jumper settings around to no avail. Device manager says both drives are working fine.
Any suggestions?
Put the ROM on a different IDE channel or get a different brand ROM. My LG ROM won't work in DMA when it's on the same channel as my Plextor burner. BTW, I think LG and Hitachi drives might share some components, since those two companies have joined forces in the optical drive market.
Thank you nic2k4. Sadly do not have a spare IDE channel so it looks like a new DVD-ROM might be required unless anyone else has any an alternative solution.
Which DVD-ROM might succesfully run alongside the NEC ND 3500-AG DVD Writer on the same channel? -
I had the same problem. After doing all this authoring, burning, etc....My dvd rom wouldnt recognize dvds.
I did a google on my dvd rom ,.. and found out that one of microsofts updates was causing the problem. I then found out that I had to update the firmware/software for the dvd rom.
Type in the name of your dvd rom in Google and then type the symptoms or "trouble shoot". -
Have you tried with one DVD as a slave on the primary channel? Move whatever is slave there now, to the secondary channel.
PINNACLE STUDIO 11 - dvd no audio plays
By ancient in forum Authoring (DVD)Replies: 2Last Post: 10th Jan 2012, 09:07 -
Converting Horse Feathers DVD to MP4 - audio plays too fast
By wkrick in forum DVD RippingReplies: 3Last Post: 7th Mar 2011, 19:04 -
Authored DVD plays 3 seconds audio/No video
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 21Last Post: 6th Jan 2011, 15:26 -
Video DVD that doesnt play audio on DVDplayer but plays fine on computer ?
By hiavi in forum Video ConversionReplies: 6Last Post: 15th Jan 2009, 15:01 -
DVD Audio Plays On DVD Software But Not On Windows Media Player 11
By CurtisMinBC in forum AudioReplies: 2Last Post: 29th Jun 2007, 13:39
