  1. Have been trying to do a quick dvd from Bin Files . Have had the same messages on 2 different titles
    Version:SVCD2DVD 2.0 RC5
    Type: System.ArgumentException
    Source: System.Windows.Forms
    Message: Controls created on one thread cannot be parented to a control on a different thread.
    InnerException:
    StackTrace: at System.Windows.Forms.ControlCollection.Add(Control value)
    at x3284ccece41ee22b.xddb8d1ea6c9958c7.x5aa416b67ec23 fff(x5d3356d9dffccb60 xc2a2a5b3a558ba7a)
    at x3284ccece41ee22b.x210ff09a2516b1a7.xb3fbc61e17e47 28c()
    at x3284ccece41ee22b.xe4d2667f3c3c2e1b.xc235541933b56 33b()
    at x3284ccece41ee22b.xe4d2667f3c3c2e1b.xa167076587a68 80d()
    at x3284ccece41ee22b.xd3764d4f1e921081.x12cbe7a4e46ac 9ae()
  2. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    It is a known issue and is fixed in the next release RC6.
    Workaround: As you are doing a "Quick DVD", this means that no menu will be created. Therefore make sure you don't go to the Menu Screen before you click "Quick DVD" as this is causing this error.
  3. Thanks
    Easy when u know how ...
