I have an internal modem at the moment, and i was wondering is it possible to install an external modem, while leaving the internal modem attached, but still able to dial up from external modem? thanks
Yes.
When you setup your dialup details, you can also choose which modem you want.
Regards.Michael Tam
w: Morsels of Evidence -
Just curious, but why would you want to? I don't think you can connect both at the same time. There are some modems (shotgun) that can do this.
Yes you can! Windows 98 (not sure about XP) has a built in "shotgun" type of technology. It will allow a dual modem setup to double the bandwidth. You don't need to purchase a Diamond Multimedia Shotgun Express modem to do it.
Your ISP MUST allow multiple logins though, and not many do.
BTW, "Shotgun" is just the term coined by Diamond for their modem. ADSL technology has had piggybacking modem connections for years, but nobody uses it any more.Cheers, Jim
My DVDLab Guides
New modem - DOCSIS 3.0, anything I should know?
By Xylob the Destroyer in forum ComputerReplies: 1Last Post: 5th Dec 2009, 20:13 -
Router for USB Cell Modem
By Poppa_Meth in forum ComputerReplies: 3Last Post: 11th Jun 2009, 19:02 -
canot connect to modem
By romanstopme in forum ComputerReplies: 5Last Post: 17th Dec 2008, 12:39 -
Which modem router to get?
By Tbag in forum ComputerReplies: 3Last Post: 1st Jun 2008, 16:54 -
Vista modem drivers.
By Poppa_Meth in forum ComputerReplies: 5Last Post: 1st Nov 2007, 10:32
