    Dec 2004
    Is there any way to compress a VIDEO_TS folder with compressor?
    I know I can use popcorn or DVD2oneX, but I was wondering if compressor will work.
    A picture is worth a thousand words, but a good camera is worth about a thousand bucks.
  2. no... compressor encodes video files into mpeg2, which are then authored into a VIDEO_TS folder using something like Toast or DVDSP.
    popcorn will transcode an existing VIDEO_TS folder and compress the entire structure to fit onto a 4.7 GB DVD and burn it in one step.
    dvd2onex does the transcoding, but doesn't do burning.
    Dec 2004
    Great, thanks.
