I have lines on my TV (and PC, too I think) in almost all the video I encode. They are horizontal, all the way across, evenly spaced, from the top to the bottom, very light you can hardly see them. I don't know if it's my DVD player or the video themselves. It's not an interlaced effect because none of my video I encode is interlaced. A lot (if not all) of the retail DVDs I play are interlaced and the TV picture is always good. I use TMGEnc to encode to DVD mpegs even though most files I encode are VCD quality. I've encoded using CBR and VBR >= 4000 kbps. For instance I'll have a wmv@1750 kbps and I'll encode it to mpeg@4000 kbps. I increase the bitrate because the encoder increases the output resolution. I have a cheap $45 Apex DVD player but like I said it plays retail DVDs fine. Have any ideas?
Hi rjc7394,
1. What's the source? In terms of file type (use GSpot, post a screen print) and where are they from - cam, downloads etc.
2. If it's destined for TV, it needs to be interlaced - irrespective of the source. That's why your interlaced commercial DVDs are OK...
3. Try swapping the field order - it could be that...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room.
Horizontal distortion lines
By hyku1147 in forum Newbie / General discussionsReplies: 5Last Post: 27th Nov 2011, 11:02 -
Horizontal Lines Appear In DVD
By Mark-Leon in forum MacReplies: 33Last Post: 17th Oct 2010, 11:23 -
horizontal lines in mpeg2
By thecrock in forum Newbie / General discussionsReplies: 6Last Post: 15th Dec 2008, 18:05 -
Horizontal Lines - Converting
By jooleyen in forum Newbie / General discussionsReplies: 5Last Post: 10th Mar 2008, 20:59 -
Help - Horizontal Lines
By Hiram_Abif in forum Newbie / General discussionsReplies: 8Last Post: 9th Aug 2007, 13:06
