Pioneer Requires u do their firmware update in MS DOS NOT!! MS DOS mode.
Problem is their latest Firmware, the 2 files required are 1.41mb and they say to put these onto an MS DOS boot disk.
How am i able to do this?
Thanks for those that help :-)
You don't flash it in DOS.
Read the instructions that are provided with the flash. -
And by all means don't flash if you are not having problems. Don't know how to do the flash properly, then don't do it. Too many people are rendering a good drive useless by not following the instructions plus basic firmware update rules. If it ain't broke it don't need fixin.
Rich DVD,
It has a MASSIVE WARNING on the Pioneer site TO BE USED IN MS DOS ONLY and DONT USE IN MS DOS MODE!Thanks for those that help :-)
Pioneer DV-220V-K firmware
By totonionio in forum DVD & Blu-ray PlayersReplies: 2Last Post: 18th Apr 2013, 08:45 -
Pioneer DV-S838A firmware
By zhudinglong in forum DVD & Blu-ray PlayersReplies: 0Last Post: 21st Jul 2011, 01:12 -
Pioneer DVD recorder firmware
By jh76 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 11th Apr 2009, 02:03 -
How do I update the firmware on my Pioneer 109 DVR?
By Boogie7910 in forum DVD & Blu-ray WritersReplies: 2Last Post: 26th Nov 2007, 04:44 -
Changing the internal PIONEER DVD-RW DVR-109 Drive's Region Settings
By vidmarc in forum MacReplies: 5Last Post: 4th May 2007, 08:48
