Anyway to do this? I have a philips dvp642 dvd player, btw
Use vcdgear or vcdeasy or isobuster and extract all the mpgs and burn them to a dvdr as iso files,if you want a menu then they will have to be authored as svcd-dvd which dvd-lab can do or use dvdpatcher with tmpgenc dvd author.
https://www.videohelp.com/forum/viewtopic.php?t=233348 and/or https://www.videohelp.com/forum/viewtopic.php?t=129786 might be able to assist you.
If in doubt, Google it. -
Thanks for the links. I extracted all the mpgs but how do i combine them to an iso?Originally Posted by johns0
Just add them to a dvd-iso compilation in nero and burn.If you want to join the movies together then you can use tmpg mpeg tool merge and cut but you might get audio sync problems,best just to add them without joining and burn.
After extracting the mpegs with VCDGear or CDEx, patched it with DVDPatcher (or SVCD2DVDMPG), use TDA to author. Just add them as parts of the same title, remove the chapter point TDA inserts at the "join".
/Mats
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 16:25 -
extracting the bin/cue from .oo1,.002 etc files
By belwas in forum Newbie / General discussionsReplies: 5Last Post: 7th Jan 2010, 01:59 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 07:06 -
The FilmMachine Xvid to SVCD conversion not creating Bin/Cue files
By louv68 in forum Video ConversionReplies: 2Last Post: 24th Jul 2007, 10:11 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 22:29
