Iv been having alot of problems with mine not reading or buring disks so i decided to take it apart and i found out that the cause of this problem is a aliment problem with the dvd/cd tray and the stupid thing is that if you leave the front panels off of the dvd drive the dvd burner works fine but as soon as
you put it back on it causes a aliment problem.I not keep the plastic panel off of the front of my dvd burner and it works fine and its better now i upgraded the firmware to the latest now its region free and its 4 speed instead of 2 speed http://forum.rpc-1.com/dl_all.php for all dvd firmware
movies do we watch them or do they watch us?
So you upgraded the firmware and everythings good?Originally Posted by newbievamp
Did you mean to say that you kept the face plate off?
My problems with this burner turned out to be the cable that came with it.
Update- Died for real May 11 2005
Replaced on the spot with a GSA4163b 8)
A good divorce beats a bad marriage.
Now I have two anniversaries I celebrate!
Problems with DVD LG GSA-4160B
By Jomapil in forum DVD & Blu-ray WritersReplies: 6Last Post: 11th Feb 2009, 00:33 -
LG GSA H55N region free?
By Ace-Of-Spades in forum DVD & Blu-ray WritersReplies: 2Last Post: 6th Feb 2009, 09:18 -
lg gsa-4120b dvdwriter
By mustang1967 in forum DVD & Blu-ray WritersReplies: 1Last Post: 30th Jun 2008, 00:50 -
LG GSA-H22N misidentifies RW media
By Overwind in forum DVD & Blu-ray WritersReplies: 1Last Post: 13th Aug 2007, 14:54 -
Cant update my LG GSA-55L firmware?
By kiaconcepts in forum DVD & Blu-ray WritersReplies: 1Last Post: 28th Jul 2007, 08:59
