Hi,
I am an absolute beginner on this, so please excuse my ignorance on this topic:
I have a DVD (my own) which has a bunch of songs.
Here is what I want to do:
Play the DVD (VOB Files)
When it reaches the song (which I want to clip from the DVD)
Start capturing the song - Start of CLIP
When the song ends
Stop capturing the song - End of CLIP
Write that CLIP into a VIDEO format
Repeat the process for x numbers of songs
When I am done, create a DVD of all those CLIPS
Here are my questions:
A. Is it possible
B. What software would I need to achieve this
C. What are going to be the STEPS involved (in the EXACT sequence) to do this
D. What is the exact technical term for this process? Would this be called VIDEO EDITING?
Thanks in advance for your guidance and advice
DVDShrink->Re-author->Start/End->Back-up.
Put each clip in it's own folder(eg clip1,clip2,etc),then use DVDShrink->Re-author and locate each folder and drag the title over to the left window->Back-up.
Use DVDDecrypter or Nero to burn.
Creating menus: DVD Styler re-encoding question.......
By bahjan in forum Authoring (DVD)Replies: 3Last Post: 21st Dec 2011, 06:54 -
Question about creating dvd's
By Bamahusker in forum Newbie / General discussionsReplies: 2Last Post: 30th May 2011, 16:57 -
Newbie question for creating a DVD
By DaBooch in forum Newbie / General discussionsReplies: 4Last Post: 28th Mar 2010, 18:51 -
Do I need to stop clip analysis in order to export clip for dvd
By maevek1 in forum MacReplies: 0Last Post: 9th Apr 2008, 09:26 -
Question about creating a continuous loop dvd
By sabina1986 in forum Newbie / General discussionsReplies: 5Last Post: 4th Dec 2007, 17:00
