    Feb 2005
    finland
    i have install the lastest codec for DIVX 5.2.1. but i have a video div3 low motion and another div3 fast motion. non of my player is able to play. they are demanding a codec for it.
    ffdshow for playing.
    if you are going to convert install https://www.videohelp.com/tools?tool=DivX_3.11
    Feb 2005
    finland
    no i just want to play video.
    Dec 2004
    Australia
    No need to install DivX3.11alpha even if you are converting. If you are converting from DivX3 to something else, ffdshow can decode it and if you want to convert to DivX, ffdshow can encode it.
