Is there anyway you can make a custom menu for your VCDs? I want to create a menu kinda like the ones on DVDs where you can click to play the movie, click to see photos, and additional info, etc. I don't need "Jump to Scenes" feature. This sounds complicated. I'd like to have a couple choices that audience can choose. I also would like to use my own background photo and the position of the menu,etc.
I played with Nero's menu function for a bit. It seems to be very limited. You don't get to see your own menu design. You don't know what you are getting.
Is it possible to create a custom menu for a VCD?
Thanks.
Shaun
with Nero you can create a menu with still thumbnails. each thumbnail is for a seperate Mpeg file. and, even after you drag and drop your Mpegs, you can select from the clip what you want the picture of the thumbnail to be from that clip and you can preview your menu page to make sure its what you want.....
VCDImager has advanced menu functions--i think it can do what you're looking for. you have to write the the functions in XML, though. not a simple GUI app.
You can make an advance menu for (S)VCD with VCDImager if you know about XML code enough, but you wont be able to use "Click or Highlight" as in DVD menu. VCDImager support only "BSN" meanning you control all funtion with numeric and also by "next" "previous" button.
Main menu/chapters/audio etc all on one motion menu in Encore. Possible?
By Killer3737 in forum Authoring (Blu-ray)Replies: 10Last Post: 11th Feb 2012, 13:08 -
Panasonic DMR-EZ48VK How do I get into its hidden setup menu (Service Menu)
By RS456 in forum DVD & Blu-ray RecordersReplies: 20Last Post: 14th Nov 2011, 01:50 -
Make menu for a movie dvd that have subtitle and have not any Menu!
By p_samimi in forum Authoring (DVD)Replies: 1Last Post: 13th Feb 2009, 14:29 -
Problems when creating a mix with motion menu and static menu
By ihmcjacky in forum Authoring (DVD)Replies: 59Last Post: 15th May 2008, 11:01 -
How to create IFO &BUP file for DVD menu[have menu vob]
By Aliyans in forum Authoring (DVD)Replies: 3Last Post: 28th Dec 2007, 11:36
