I've been using DVD-Lab without problems for some time and recently started using Vegas 5 but have run into a strange problem with DVD Architect.
If I create a submenu page for all my chapter markers and then burn it and play it in my main test DVD player - a Pioneer - when I select the submenu image the DVD goes into Stop mode. If I then press Play it plays from the beginning but the only way to access the chapters is via the Forward and Back arrows.
Even stranger is that the same DVD behaves properly in PowerDVD, another Pioneer DVD Player, the JVC DR-10M and a Magnavox player - just not my main test player - in which everything burned with DVD-Lab has always worked fine. It's the same whether I burn +R or -R.
I don't want to give clients disks that may not play properly in their players. Any known workarounds?
Thanks.
Results 1 to 1 of 1
Program to burn only select portions from a dvd to blank dvd?
By cv50 in forum Newbie / General discussionsReplies: 2Last Post: 26th Jul 2011, 20:17 -
dvddecrypter stop recognize dvd in drive, got img burn,it stop recognize
By ninjinturdle in forum Authoring (DVD)Replies: 3Last Post: 21st Jun 2011, 13:30 -
GfD: delete a submenu?
By AlanHK in forum Authoring (DVD)Replies: 11Last Post: 22nd Mar 2009, 08:08 -
DVD Architect 4.5 missing "Insert: Submenu from file"
By sir_rob in forum Authoring (DVD)Replies: 1Last Post: 1st Aug 2008, 12:39 -
extracting audio from submenu
By juetenglord in forum Authoring (DVD)Replies: 3Last Post: 18th Feb 2008, 08:29
