I have tried to convert an xvid file to dvd but i am having real problems - i have tried using several programmes to convert eg alive video converter & winavi video converter and lots more but each cant open the file.
it plays on windows media player no problem as i have installed the codecs but for some reason cant convert here is the info from avicodec and hopefully someone can advise what im doing wrong
File : 700 MB (700 MB), duration: 1:36:14, type: AVI, 1 audio stream(s), quality: 52 %
Video : 613 MB, 891 Kbps, 25.0 fps, 624*256 (2.43:1), XVID = XVID Mpeg-4, Supported
Audio : 86 MB, 126 Kbps, 48000 Hz, 2 channels, 0x55 = MPEG Layer-3, Supported
I would love some help here
thanks
Results 1 to 9 of 9
have you tried installed koepies xvid codec? no codec packs or ffdshow.
ive installed ffdshow and that just made it play in media player etc but still wont convert - i havent tried xvid codec yet tho - ill give that a try now and let you know what happens - thanks
well i tried xvid codec and the encoder programme i used was alive video converter, it started to encode then just froze at 60% - i have tried some others and one stated there was no video file?? tmpgenc opened it but said the file was far too big for disk?? when its only 700mb - is there something wrong with this file? should i give up now??
help would be muchos appreciated.
As your audio regarding the report from avicodec is 126 Kbps (128 is the standart) I assume your audio is VBR. Load the file in VDub, select direct stream copy for video, disable the audio (No Audio) and Save as - give name save as avi. You will have an avi without sound. Load this avi in tmpg and encode. TMPG and most other mpeg encoders don't like VBR audio files.Originally Posted by floster
thanks, im going to try that divx to dvd programme - seems to be working so far - ill post you the outcome!!
VLC is one of the most robust players, and is designed to play back partial files and multi-part download files that others choke on. Because of this it is invaluable for playing back difficult files, but can hide the fact that a file is too corrupt for other programs to work with. In your case, I would say that you definately have cprruption at around the 50 minute mark.
I would scan it with DivFix to see what state it is in.Read my blog here.
Conversion Problem
By Myrdivar in forum Video ConversionReplies: 3Last Post: 2nd Jun 2011, 04:44 -
Problem with conversion to DV
By SteveDM in forum ffmpegX general discussionReplies: 3Last Post: 25th Aug 2010, 08:54 -
conversion problem
By thomeski in forum Authoring (DVD)Replies: 2Last Post: 25th Apr 2010, 20:45 -
Help conversion problem!
By milney100 in forum Video ConversionReplies: 6Last Post: 11th Jun 2008, 05:51 -
video conversion problem
By eagle1 in forum Newbie / General discussionsReplies: 5Last Post: 2nd Jun 2008, 21:25
