    Jul 2004
    huntington beach
    I'm trying to convert a DV cam capture to Divx...it's 44 minutes, 720x480....trying to covert to same size, same framerate.
    Basically what I get is a 5 minute clip.....super fast....like most of the frames are just dropped.
    The DV file is 9gb
    What am I missing, is this a bug with ffmpegX?
    -Josh
  2. Try to enable "Decode with Quicktime", yes it is a known bug of ffmpeg. Using the "Decode with Quicktime" option should fix.
    Jul 2004
    huntington beach
    Hmm, I can't even try with the "decode with quicktime" option because I get:
    AppleScript Error
    The variable _frameratey is not defined. (-2753)
    The source is 29.95, which I left the same for encode.
  4. Try to use NTSC 29.97 from the popup list.
    Jul 2004
    huntington beach
    Excellent. Thanks for the extremely fast help Major! I'll will be registering....right....now!
