I started to write that up in my last reply but got lazy!Originally Posted by FulciLives
Results 91 to 97 of 97
Well truth be told I am the lazy one. I started my current job in March of 2005 but technically didn't become "full time" until August 1st 2005. I got 6 "personal" days this year anyways (that is the max all employees get for a full calendar year).Originally Posted by junkmalle
I've only used 2 of them so far but I used one on Tuesday then again yesterday and against my better judgement I called off again today. All of this under the "guise" of being "ill" ... my job is a phone job doing collections so if you are sick and your voice is "messed up" you can't really work now can you?
So I'm the lazy one LOL
Has anyone tried the seemingly simple instructions at http://www.ehow.com/how_6122094_change-pal-dvd-ntsc.html to convert PAL dvds to NTSC dvds using 3 free programs?
If it works then the remaining question is whether the converted video and audio quality is good. Since I only have 6 PAL dvds to convert I don't mind if the conversion takes hours of computer time per dvd.Last edited by paltontsc; 15th Dec 2014 at 18:10.
Thanks!
That seems to confirm that there still is no easy pure-software solution to this after over a decade of folks asking for the same thing.Last edited by paltontsc; 15th Dec 2014 at 18:18.
AvsToDVD does a proper job of it, using 3:2:3:2:2 pulldown after the encoding is finished. You won't get back converted menus, though, but a fairly rudimentary menu, if you like. And it'll still have the PAL speedup, as all DVD conversions done this way will.
These days I'm pretty lazy and I often use AVStoDVD if I need to do a PAL 2 NTSC conversion. Assuming the PAL DVD is progressive and doesn't have any odd interlacing issues then AVStoDVD does a damn fine job.
PAL / NTSC DVD Conversion (patch method)
By DJRumpy in forum User guidesReplies: 271Last Post: 12th Mar 2020, 19:13 -
Simple click and go method to convert PAL to NTSC
By THRobinson in forum Video ConversionReplies: 15Last Post: 26th Feb 2011, 01:16 -
Best Method Convert PAL VOBs to NTSC
By ehmjay in forum MacReplies: 13Last Post: 28th Jul 2009, 16:54 -
PAL to NTSC DVD [Full Disc] Conversion (hybrid method, very easy)
By LadyLiete in forum User guidesReplies: 28Last Post: 5th Nov 2007, 21:35 -
Automatic selection PAL NTSC & command line switch method
By joecon in forum Capturing and VCRReplies: 0Last Post: 13th Sep 2007, 08:13
