Hi
I want to buy a Dell 30" lcd tv which only has NTSC tuner
but I want to use it in Europe which is PAL,
so how can I use that lcd tv for tv and dvd player
first, I head that there are some converter that converts PAL signals to NTSC.
Are those converters good for digital signals? what to consider when buying those converter
second, there are some players which are multi sistem(ntsc and pal), so I guess I can watch any dvd since those dvd players will convert to ntsc,
but I also have some suspicous about those players, is the sonversion also good on those players.
Plain truth?
You will not be able to use that TV here in Europe unless it has an extra auxiliary input. An NTSC tuner in PAL-land is useless.
By using the aux. input (if it has one) you will need to use a European VCR as your TV Tuner....then input to the TV via the aux. input.
Only some DVD Players actually do a true NTSC to PAL(or vise versa) conversion. Most (like one of mine) will create a "quasi" signal....a signal that will basically fool the TV into displaying the signal.
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
Analog Cable TV to HD LCD Monitor via TV tuner
By torrentkid in forum DVB / IPTVReplies: 0Last Post: 3rd Aug 2010, 07:19 -
LCD HDTV 1080p with HD tuner.. grainy!
By Browncoat in forum DVB / IPTVReplies: 5Last Post: 21st Dec 2008, 21:06 -
pal/ntsc lcd monitor question
By scotstrength in forum Media Center PC / MediaCentersReplies: 0Last Post: 30th Oct 2007, 13:17 -
Which TV tuner playing well with widescreen LCD?
By SingSing in forum Newbie / General discussionsReplies: 1Last Post: 5th Oct 2007, 10:27
