I have not seen much help on this specific file. I have quite a few video files that I have captured from old VHS home movies using an ATI TV Wonder capture card, it creates a .mp2 video file...and I have quite a few of them.
I just recently purchased a DVD burner that came with NeroVision Express 2 to create DVDs with however, I have not been able to convert and burn any of my many .mp2 video files to DVD using this program.
Anyone have a suggestion on what to do or to use?
Thanks.
Results 1 to 14 of 14
what does nerovision express say? any error?
what is the mp2/mpg source file properties? is it dvd compliant? use avicodec to identify the properties www.videohelp.com/play#identify
and try Tmpgenc DVD Author! -
.mp2 is usually extension of mpeg 1 layer 2 AUDIO files. For video is used .m2v or .mpv extensions. You confuse me very much with this ".mp2 video". Are you sure it is video?
Yup.
If need be, I can post one of the videos on my web site to show an example. -
Nerovision actually times out (hangs) on them. I haven't really deteremined yet if it is a utility issue, not enough PC resources issue, or DVD burner issue. I've been able to convert other media files (.avi, .mpg, etc.) to DVD with no issues.Posted: Mar 08, 2005 07:28
I will check the properties when I get home later this evening and post. -
Originally Posted by Abond
a couple of programs call program stream mpeg2 files xxx.mp2 ..
but otherwise you are right ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Hm.. ah.. hm.. maybe r_deckard9 can simply rename it .mpg and the applications will get it right. Stupid solution, but it may work...Originally Posted by BJ_M
The utility detected the properties as such. V. codec name=MPEG 2 (SVCD/DVD) and A. 1 codec name=Mpeg-1 audio layer.use avicodec to identify the properties www.videohelp.com/play#identify
I am about to try the trial version of Tmpgenc DVD Author to see if I can burn it to DVD with that. -
Tmpgenc DVD Author failed. As soon as I opened the file it encountered a problem stating "The video resolution 640x240 cannot be used for a standard DVD" and "The video framerate 29.97 fps cannot be used with the resolution 640x240".
I did try this and it burned to DVD successfully using NeroVision Express, however there was no sound to the DVD.Hm.. ah.. hm.. maybe r_deckard9 can simply rename it .mpg and the applications will get it right. Stupid solution, but it may work...
I tried again to burn the 550MB .mp2 video file using NeroVision Express and it hung on me again.
Very frustrating. -
I don't really know. You'll have to forgive me, I'm completely new to all this video editing/burning stuff.
All that I know is that it was a transfer/capture from a VHS home movie. So, if the camcorder and capture card I use transfers it that way, maybe so.
Looking at this error message, do you think I would need to use a double-layer, 8GB DVD to burn this video."The video resolution 640x240 cannot be used for a standard DVD" -
you need to re-encode it to a standard dvd resolution
to bad you will loose quality ...
should have capped it different .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Well, video resolution 640x240 is not in the DVD standarts SL or DL it is always DVD. So the resolution is not supported.
To check if they are such a resolution either load it in GSpot (latest version) and look the resolution it reports or load in VirtualDubMod and look at File->File information. Look also the audio properties - if you try to make NTSC DVD you probably will need an AC3 audio (PAL can live with MPEG1 Layer 2 audio).
If it is posible try to capture again using resolution that match DVD requirements. If not - patch the files with DVDpatcher to valid resolution and after they are accepted patch them back to the original resolution. I know people doing this, but I never done it, then I can be wrong here.
The other only option is to re-encode the files to valid DVD properties.
Looking for Tried and Tested mp4 to mp2 settings for DVD
By AndyInBuffalo in forum ffmpegX general discussionReplies: 0Last Post: 7th Mar 2012, 12:42 -
How do I make a Blu Ray disk from an MP4 or MP2 file?
By True Colors in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2010, 05:26 -
mp2 & wav compatible DVD authorers?
By Bassquake in forum Authoring (DVD)Replies: 4Last Post: 2nd Feb 2009, 15:11 -
Convert mp2 file in TMPGenc
By sdlehman in forum Video ConversionReplies: 1Last Post: 17th Mar 2008, 17:53 -
audio PCM to MP2 while retaining DVD menus
By navels in forum Video ConversionReplies: 2Last Post: 20th May 2007, 16:51
