I was told by a friend that TMPGEnc could be used to edit out commecials of captured TV shows. However it seems I can only do one start/end point. Am I missing something? Or am I going to have to cut each segment as a file, then splice them together afterward? If TMPGEnc can't do it which program can? I need something that can do a batch convert. I have alot of episodes that need to be cut.
I think this may-be what he was talking about.
https://www.videohelp.com/tools?tool=TMPGEnc_MPEG_Editor -
It will depend on which version of TMPG you have.
I my 2.520 version, you can edit out multi-segments in one sitting.
Here's how (assuming you have a version that allows) I do it, but
first verify you have a special feature (I'll BOLD it to make
it known, inside my steps below) ...
1 tmpg and open your source
2 settings/advance tab
3 select [x] Source Range (by dble-clicking the [x] box)
4 Verify that you have this button below the video window, Cut editing
5 now, highlight the section w/ the 1st commercial you want to cut out
6 when highlighted (blue) click inside the video area once and then press DEL
7 Now, find you 2nd commercial and do the same, 5-6 steps until you are done.
8 NOW ENCODE YOUR VIDEO.
If you have Cut editing button, you are set to go
-vhelp 3203 -
You might want to try AviSynth and VirtualDubMod.
Much easier to place the edits exactly where you want and you can preview before hand much better.
Here is a guide I wrote that covers how to edit this way as well as how to use the popular Convolution3D "video noise" filter.
https://www.videohelp.com/forum/viewtopic.php?t=225951
Good Luck !
Re problems editing in tmpgenc authoring works 4 using multiple video files
By ukcalibrauk8 in forum Authoring (DVD)Replies: 4Last Post: 2nd Jul 2011, 02:25 -
Editing Commercials
By Jacks_Daddy07 in forum EditingReplies: 2Last Post: 18th Oct 2010, 23:09 -
Accurately editing commercials from HD PVR h.264 .ts files
By finallygreen in forum Video ConversionReplies: 10Last Post: 28th Oct 2009, 14:14 -
Help with output after editing with tmpgenc 4.0 xpress
By uka100 in forum EditingReplies: 2Last Post: 14th May 2008, 20:30 -
Editing w/ TMPGEnc 4.0 Xpress
By JOHNTOUPS in forum EditingReplies: 7Last Post: 20th Feb 2008, 15:27
