My computer doesn't currently have firewire support. I am preparing capture my home videos and more with my zr65 (analog to dv pass through).Soooo
are all firewire cards the same for what I want to do. I am going to connect the firewire i/o of my canon zr65 to a firewire port on my computer. I have seen pci firewire cards for $10 on up. I was actually considering getting a canopus advc 50 but I was wondering if this would make a difference in the quality of the capture (especially when I moved on to passing vhs through the camcorder)
If your pass through works on your camera, that is basically the same as the ADVC. The ADVC may be more convenient, but it will work just as well, quality wise.
As far as Firewire cards, yes, they are mostly the same. I don't know that I would spend as little as $10US for one, but $15-20 should be sufficient.
They are becoming more common now with all the camcorders out, the prices are very reasonable. -
Firewire is not a "capture" it is a real time data transfer.
As with everything else, things are made using different components.
Some may or may not be more compatable with other components in your system
More $ is not always the correct criteria.
Functionally they should in theory be the same -
If using with Windows XP, make sure the card is OHCI (open host controller interface) compliant. Similar to these in the link. No special driver will be needed. Different rules apply for Win98, Linux and Mac.
http://www.ramelectronics.net/html/ieee-1394_host_adapter_card.html -
get a ADAPTEC FIREWIRE PCI CARD from COMPUSA on sale right now for $20.00. I use that card on all of my pc's including the one with XP PRO. No problems at all.
Budz, I thought you'd suggest newegg.com before Compusa.
I personally find newegg and zipzoomfly (formerly googlegear) to be the best deals on computer supplies. -
Yes, I am a Newegg.com whore but shipping costs are 2day FEDEX to Honolulu, Hawaii therefore COMPUSA is cheaper for that ADAPTEC FIREWIRE CARD. I buy other computer components like CPU, MOTHERBOARD, & DVDRW from Newegg.Originally Posted by Malchiah
What do you used for a PCI xpress firewire card?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 7Last Post: 5th Sep 2011, 21:45 -
Need to buy a suitable PCI X firewire card for my newish PC ASAP
By Canon GL-2 Guy in forum ComputerReplies: 2Last Post: 5th Sep 2011, 00:08 -
Good Firewire PCI card for Capturing HDTV?
By superdud1400 in forum Capturing and VCRReplies: 1Last Post: 12th Jun 2008, 06:11 -
I need a good FireWire PCI card for capturing video.
By mob in forum Capturing and VCRReplies: 11Last Post: 1st Apr 2008, 02:19 -
Canopus ADVC-100 and PCI Firewire card
By spiderbaby in forum Capturing and VCRReplies: 12Last Post: 5th Mar 2008, 09:39
