  1. Okay this is my situation in short form:
    1. i make music videos for fun and that is the purpose of this topic
    2. i want to rip episodes onto my computer with a smaller size then what i am getting.
    3. currently i am using DVD Decrypter, and i rip the VOB off and i convert it to MPEG with TMPGEnc Express. the files are 630 mB for a 22 min episode. taht is a bit big...and i know it can be smaller, im a "newb" i guess at ripping ^_^.
    i looked at the guides and did not understand half of them and the other half had nothing that directly relates to this situation.
    can i get some help with this please? i figure that the files shoudl be more like 220-240mB becuase a 4 min song in MPEG = approx 40-50mb.
    thanks in advance.
    USA
    Here's a bitrate calculator:https://www.videohelp.com/calc.htm
    You can use it to see what size a video will be when encoded. You adjust the bitrate lower to make the filesize smaller. Too small and the quality suffers. Also using AC3 audio or at least MPEG-1, layer 2 will make the filesize smaller.
    If you plan to store these on computer for viewing, DIVX may be a better solution. It is much more compact than MPEG and you can use MP3 audio.
  3. ahh thank you i will try this tomarrow, (really late right now)
    if you dont mind me asking, could u explain how to do it in avi? or point me to a guide thats easy to follow ^_^
    i plan to make music videos with the episodes i rip. i just bought them off ebay and wnated to do it fast, and i was goign to store them on a cd or something so i wouldnt have to re-rip it everytime (Say i got a new idea for a video that would require me to use it).
    thanks in advance!
  4. Mod Neophyte redwudz's Avatar
    USA
    Here's one guide to get you started. It uses Virtualdub (Freeware) for DIVX or other AVI conversion.
    https://www.videohelp.com/avi2divx.htm
    There are several ways to do it, and many types of AVI formats. Virtualdub is a good tool to learn how to use. It does conversions, filtering, frameserving to TMPGEnc, simple editing, many other things in several AVI formats.
  5. thank you very much i will use these as best i can and post if i have any more problems
  6. Member encman's Avatar
    Mar 2005
    Portugal
    Sorry to interrupt your conversation, but i downloaded that bitrate calculator and got BYTEVERIFY WORM,ok?
    FIREFOX FOREVER
  7. Mod Neophyte redwudz's Avatar
    USA
    I really doubt you got a virus from this site, but you should PM Baldrick (The administrator of this site) with that info.
