It's a silly question that I couldn't find an answer to in the FAQ. But I've an old VCR tape with some audio dropout problems. Is there any way to reduce or eliminate the dropout effect?
Thanks!
I've done this using Adobe Premiere. First you need to unlink the audio and video tracks. You then "cut" the audio for each "dropout". Then find an acceptable audio portion, razor that portion, and copy to the clipboard. Then "paste" into the audio track for the corresponding dropout. This method works well if you have a fairly continuous sound and are only missing a frame or 2 of audio. Hope this helps.
wwaag
Could a .TS Video with an Audio Error be Repaired?
By zoomie in forum EditingReplies: 3Last Post: 7th Feb 2012, 15:16 -
Audio dropouts when capturing a particular Digital8 tape to DV
By brassplyer in forum Capturing and VCRReplies: 6Last Post: 4th Aug 2009, 20:18 -
MKV Audio Dropouts
By hcour in forum AudioReplies: 2Last Post: 12th Nov 2008, 10:09 -
The dreaded 360 ring of death -REPAIRED!
By yoda313 in forum Off topicReplies: 11Last Post: 28th Jun 2008, 10:37 -
Panasonic DVD recorder & timecode breaks / audio dropouts
By webstar in forum DVD & Blu-ray RecordersReplies: 8Last Post: 23rd Jul 2007, 18:43
