Hello All...I recently got a 693Mb AVI file that, though appears to be fine will not play.
Using G-Spot I "inspected" the file and it told me the video compression method, audio compression method, said the file length was correct (656Mb used for Video and 36.6Mb used for Audio), etc, etc BUT... said the Runtime is 1 Frame.
I've tried DivXRepair, DivFix, and DrDivx all with NO luck.
I don't suppose anyone else has run into this problem and/or know how to fix it.
Any and all help will be GREATLY appreciated.
Thanks in advance...cheers....Dean.
