Hey everyone, I need some help, I am ultra new to the whole DVD creation scene and need some advice!
What I am trying to do is burn TV shows to a dvd, but I am trying to set a menu up the way I want.. I like DVD Lab, got everything setup the way I think I wanted it to run, but (to the best of my knowledge) there isnt a way to preview the menu, make sure everything is linked and working right.. Is there anyway I could do that? Or does some one have another program they would suggest? I want to be able to pretty much make things how I want, button placement, what plays first etc..
Thanks a ton everyone!![]()
Hi aphex23,
I believe that the are user forums over at the home site of DVDLab - have a search through there. I think that there are also basic tutorials on the site - there may be one to cover your needs.
Good luck.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
mmmk... Thanks, so you think thats my best bet? I am getting Ulead DVD Workshop too, looks sweet, thought I would give it a shot
I don't know DVDLab, but I thought it worth mentioning other sources of answers, as well as this site.Originally Posted by aphex23
Don't know the tool, but hope it works out. If you want, you can comment in the tools section.Originally Posted by aphex23There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
In Dvdlab, just click Menu, Follow Links.
I have a couple of tutorials on it.Cheers, Jim
My DVDLab Guides
freemake 2 , great program , but can i have my own menu backgrounds ?
By soulbug in forum Video ConversionReplies: 3Last Post: 23rd Feb 2011, 14:01 -
What program do you use to create a menu for DVD
By Cazz in forum Authoring (DVD)Replies: 6Last Post: 24th May 2009, 13:31 -
Best Authoring Program to create full custom menu
By quik_123 in forum Authoring (DVD)Replies: 12Last Post: 11th Oct 2008, 01:46 -
Program to add a menu to a DVD...
By Soccerman77 in forum Authoring (DVD)Replies: 1Last Post: 14th Sep 2008, 04:45 -
dvd menu and sub menu program
By mikeoliver1313 in forum Authoring (DVD)Replies: 7Last Post: 20th Jan 2008, 12:31
