I have a PIII 600 384 Mb Ram 120 Gb HD
I am getting a LiteOn DVD+/-RW LITEON SOHW-1673S 16x+/-, 4x DL
for $65 delivered.
The requirement for this hardware is a P 450 or higher.
Nero 6 requires P 1.2G or higher for DVD Burning.
Is there other software that I can use that will allow me to burn DVD's with my PIII 600
That is all the money I have right now.
Thanks,
Joe
Results 1 to 9 of 9
A PIII 600 should be quite adequate for burning DVD. DVDDecrypter comes to mind for a low end system.
/Mats -
I've been transferring, encoding, authoring, and burning DVDs (with Nero 6) with a Pentium III 550. It could go a little faster, but you'll have no problem.
44E -
my system up until about 4 months ago was a celeron 500mhz with 192 megs ram and 2 20 gig drives and i never had a problem.
Yes 120GB Thanks and I corrected it
I will have to see if Nero will work
from their website
nero 6.0 update mentions the following
Processor and installed memory
For writing audio and data discs:
- 500Mhz Intel® Pentium III processor or equivalent
- 64MB RAM
For DVD and video authoring:
- 1.2Ghz Intel® Pentium III process or equivalent
- 128MB RAM
For real−time capturing and burning:
- 1.6Ghz Intel® Pentium IV processor or equivalent
- 128MB RAM
http://www.nero.com/us/Nero_6_Ultra_Edition_Update_System_Requirements.html -
trust me, it works. mind you i didn't do other stuff while i was burning, but i never had a coaster and i burned a lot of discs on that system.
This is what you should be concerned about - And you're fine at this point.Originally Posted by JoeBolden
Nero shouldn't be used for these purposes anyway, so it should be of no concern.Originally Posted by JoeBolden
/Mats
Capture software for ATI HD Wonder 600 PCIe
By Spektre in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2011, 09:31 -
TV Wonder 600 and TV Wonder HD 600, is there any real difference?
By jedi55 in forum Capturing and VCRReplies: 3Last Post: 20th Mar 2011, 22:53 -
best free software to burn dvd?
By sgbd in forum Authoring (DVD)Replies: 10Last Post: 17th Oct 2010, 08:57 -
Best software to burn my dvd files
By superJT in forum Authoring (DVD)Replies: 10Last Post: 18th Aug 2008, 21:35 -
Burn Software with Menu & burn xvid avi
By CynthiaBlue in forum Newbie / General discussionsReplies: 3Last Post: 4th Jul 2007, 21:46
