After I record tracks with my Magnavox MRV640, I try to use DVD shrink to rip some of the tracks back for personal editing & I get an error message that states:
DVD Shrink encountered an error and cannot contine.
Invalid DVD navigation structure.
Any ideas as to why this is happening??
Also does anyone know if this recorder will record 704 x 480 Resolution?
Results 1 to 9 of 9
Father knows best.
Shrink doesn't like discs made by set top dvd recorders. You'll have to use soemthing else. I rip with dvdecrypter & reauthor.
ok thanks. do u know anything about the resolution?
Father knows best. -
Well after erasing the disk comepletely & then recodring on it, Shrink now reads it. Odd huh. & I am using Latest version of Shrink.
It sounds like you are using an RW disc. It may not be DVDShrink that was causing the problems. As I recall Maganavox units are Philips units. Look for a "protect" feature in the menu after you record to the RW disc....that should take care of any future conflicts....SHOULD.
Protect feature is off, it seemed though after I completely erased a New RW disc, then recorded to it again, Shrink read it fine.
My Philips DVDR75 does the same thing.
Sometimes Shrink will not read a DVD+RW made in the R75 and if you use it again it works fine.
Have more trouble with RICOHJPN W01 (TDK 2.4x)
and INFODISCA01 (Memorex 2.4x) than RICOHJPN W11 and CMC MAG W01.
Mine seems to like the CMC best which makes sense since Phillips uses CMC for thier branded discs. -
DO you know if this recorder will record 704 x 480 Resolution?
Father knows best.
Mkv & FLV Conversion Trouble
By Simmons in forum Video ConversionReplies: 1Last Post: 9th May 2011, 12:55 -
Newb questions - re. HD&MiniDV Camcorders & Capture
By The Big Cheese in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 1st Jan 2009, 17:21 -
Trouble finding a Magnavox MSR90D6 Replacement Remote
By jolieisanangel in forum DVD & Blu-ray RecordersReplies: 4Last Post: 22nd Nov 2008, 11:13 -
Questions About Two Magnavox DVD Recorders:
By wtsinnc in forum DVD & Blu-ray RecordersReplies: 7Last Post: 19th Nov 2008, 17:04 -
Trouble with audio to rear speakers (off & on)
By heyjjjaded in forum Media Center PC / MediaCentersReplies: 0Last Post: 20th Apr 2008, 22:50
