Hello All,
I found a really good article through the forums about maximizing IDE arrangements, but I have run into an inconsistency when altering a Dell that I want to sort out.
I am installing my DVR 109 and removing my CD-RW. I will also be adding a second HDD in the next week once a bracket arrives. My proposed configuration is:
Primary IDE:
Master = 40GB HDD (currently installed)
Slave = 80GB HDD
Secondary IDE:
Master = DVD-RW
Slave = DVD-ROM
I will not be burning on-the-fly. My confusions arises over whether I should switch to "Cable Select" once I install 80 wire cables. I have seen articles encouraging the master-slave arrangement but I have read on this forum that Dell products need to be configured in "Cable Select." Which is the better arrangement?
Thanks for you help.
Optimal tracking for video != optimal tracking for audio
By miamicanes in forum RestorationReplies: 4Last Post: 16th Oct 2014, 12:52 -
Need help getting optimal quality for DVD-5
By BlackThought in forum Video ConversionReplies: 8Last Post: 4th Apr 2012, 23:37 -
SATA or IDE DVD writer
By m baqar in forum Authoring (DVD)Replies: 8Last Post: 28th Mar 2008, 19:35 -
How to set optimal bitrate for MPEG
By peterbuilt in forum Newbie / General discussionsReplies: 2Last Post: 17th Mar 2008, 12:13 -
Optimal Video Bitrate and target DVD size
By src2206 in forum Authoring (DVD)Replies: 22Last Post: 24th Oct 2007, 07:54
